Saltar al contenido principal
GameSir G7 SE Joystick Module Replacement
Qué necesitas
  1. GameSir G7 SE Joystick Module Replacement, Interior face plate: paso 1, imagen 1 de 1
    • Remove the faceplate by prying upwards with a plastic opening tool.
    • This faceplate is magnetic and will be easy to come off.
  2. GameSir G7 SE Joystick Module Replacement: paso 2, imagen 1 de 2 GameSir G7 SE Joystick Module Replacement: paso 2, imagen 2 de 2
    • Use a T6 Torx Screwdriver to remove the six 9 mm screws from the interior face plate.
  3. GameSir G7 SE Joystick Module Replacement: paso 3, imagen 1 de 2 GameSir G7 SE Joystick Module Replacement: paso 3, imagen 2 de 2
    • Using a plastic spudger tool, remove the interior face plate. Go around all the edges, prying downwards until it's removed.
    • Make sure to hold the controller upside down; otherwise the buttons will fall out.
  4. GameSir G7 SE Joystick Module Replacement, Joystick Module: paso 4, imagen 1 de 1
    • Remove the plastic joystick that is covering the joystick module by pulling up on from the gray grip.
  5. GameSir G7 SE Joystick Module Replacement: paso 5, imagen 1 de 1
    • To gain access to the joystick module, you will need to gently bend the metal retention clips that hold the module in place.
    • Use a plastic spudger to gently bend the retention clips back.
  6. GameSir G7 SE Joystick Module Replacement: paso 6, imagen 1 de 1
    • Pull directly up on the joystick module to remove it from the motherboard.
    • Make sure to hold the joystick module from the red portion to prevent it from falling apart.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 35
Ultimos 30 días: 175
Todo El Tiempo: 302
