Saltar al contenido principal
GameSir G7 SE Interior Face Plate Replacement
Qué necesitas
  1. GameSir G7 SE Interior Face Plate Replacement, Interior face plate: paso 1, imagen 1 de 1
    • Remove the faceplate by prying upwards with a plastic opening tool.
    • This faceplate is magnetic and will be easy to come off.
  2. GameSir G7 SE Interior Face Plate Replacement: paso 2, imagen 1 de 2 GameSir G7 SE Interior Face Plate Replacement: paso 2, imagen 2 de 2
    • Use a T6 Torx Screwdriver to remove the six 9 mm screws from the interior face plate.
  3. GameSir G7 SE Interior Face Plate Replacement: paso 3, imagen 1 de 2 GameSir G7 SE Interior Face Plate Replacement: paso 3, imagen 2 de 2
    • Using a plastic spudger tool, remove the interior face plate. Go around all the edges, prying downwards until it's removed.
    • Make sure to hold the controller upside down; otherwise the buttons will fall out.
Conclusión
Memphis Collins
Miembro Desde 01/23/24
281 Reputación
2 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 17
Ultimos 30 días: 67
Todo El Tiempo: 158
