Introducción
This foundational guide is designed for the GameSir G7 SE, focusing on safely opening the device to access its internal components. Opening your GameSir G7 SE is the first step in any maintenance or repair task, allowing you to address issues from the inside out.
Before beginning, disconnect the controller to avoid any electrical risk. Be mindful that disassembling your device might void warranties.
Qué necesitas
Remove the faceplate by prying upwards with a plastic opening tool.
