Saltar al contenido principal
GameSir G7 SE Button Gaskets Replacement
Qué necesitas
  1. GameSir G7 SE Button Gaskets Replacement, Interior face plate: paso 1, imagen 1 de 1
    • Remove the faceplate by prying upwards with a plastic opening tool.
    • This faceplate is magnetic and will be easy to come off.
  2. GameSir G7 SE Button Gaskets Replacement: paso 2, imagen 1 de 2 GameSir G7 SE Button Gaskets Replacement: paso 2, imagen 2 de 2
    • Use a T6 Torx Screwdriver to remove the six 9 mm screws from the interior face plate.
  3. GameSir G7 SE Button Gaskets Replacement: paso 3, imagen 1 de 2 GameSir G7 SE Button Gaskets Replacement: paso 3, imagen 2 de 2
    • Using a plastic spudger tool, remove the interior face plate. Go around all the edges, prying downwards until it's removed.
    • Make sure to hold the controller upside down; otherwise the buttons will fall out.
  4. GameSir G7 SE Button Gaskets Replacement, Button Gaskets: paso 4, imagen 1 de 1
    • Pull up on the conductive rubber button gaskets to remove them.
    • Additionally, clean contacts with 91% isopropyl alcohol if needed.
  5. GameSir G7 SE Button Gaskets Replacement: paso 5, imagen 1 de 2 GameSir G7 SE Button Gaskets Replacement: paso 5, imagen 2 de 2
    • Make sure that the longer prongs on the button shroud/guide are facing you when reassembling.
Conclusión
Nicolai
Miembro Desde 01/23/24
85 Reputación
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 18
Ultimos 30 días: 119
Todo El Tiempo: 198
