Saltar al contenido principal
Game Boy Pocket Motherboard Replacement
Qué necesitas
  1. Game Boy Pocket Motherboard Replacement, Back Cover: paso 1, imagen 1 de 3 Game Boy Pocket Motherboard Replacement, Back Cover: paso 1, imagen 2 de 3 Game Boy Pocket Motherboard Replacement, Back Cover: paso 1, imagen 3 de 3
    • Place the Game Boy Pocket face-down on a clean, flat surface.
    • Use a Y1 tri-wing screwdriver and turn counterclockwise to remove the four external screws.
    • Use a Y1 tri-wing screwdriver and turn counterclockwise to remove the two screws inside the battery compartment.
  2. Game Boy Pocket Motherboard Replacement: paso 2, imagen 1 de 3 Game Boy Pocket Motherboard Replacement: paso 2, imagen 2 de 3 Game Boy Pocket Motherboard Replacement: paso 2, imagen 3 de 3
    • Place your hands on the front and back covers of the Game Boy Pocket, and carefully separate the device.
    • Set the back cover aside. You will need it to reassemble the device.
  3. Game Boy Pocket Motherboard Replacement, Motherboard: paso 3, imagen 1 de 1
    • Use a Phillips #1 screwdriver and turn counterclockwise to remove the three screws on the motherboard.
  4. Game Boy Pocket Motherboard Replacement: paso 4, imagen 1 de 3 Game Boy Pocket Motherboard Replacement: paso 4, imagen 2 de 3 Game Boy Pocket Motherboard Replacement: paso 4, imagen 3 de 3
    • Use a plastic opening tool to dislodge and remove the clip securing the ribbon cable.
    • Make sure you apply pressure on both sides of the clip to loosen it.
  5. Game Boy Pocket Motherboard Replacement: paso 5, imagen 1 de 2 Game Boy Pocket Motherboard Replacement: paso 5, imagen 2 de 2
    • Use a plastic opening tool to dislodge the ribbon cable.
    • Be gentle to prevent tearing the ribbon.
  6. Game Boy Pocket Motherboard Replacement: paso 6, imagen 1 de 2 Game Boy Pocket Motherboard Replacement: paso 6, imagen 2 de 2
    • Grab the black piece protruding from the motherboard, and lift up to remove the motherboard.
Conclusión
7 personas más completaron esta guía.
Adriana Rahrig
Miembro Desde 10/07/14
1,637 Reputación
5 Guías creadas
Equipo
USF Tampa, Team 1-1, Leahy Fall 2014 Miembro de USF Tampa, Team 1-1, Leahy Fall 2014
USFT-LEAHY-F14S1G1
Miembros de 4
19 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 6
Ultimos 7 días: 24
Ultimos 30 días: 100
Todo El Tiempo: 6,011
