Saltar al contenido principal
Introducción
This guide explains how to remove the outer case so that you can access the internal components of the Game Boy. This will be helpful for other guides related to this hand-held gaming console.
Partes
No se especificaron partes.
  1. Game Boy Outer Case Replacement, Batteries: paso 1, imagen 1 de 2 Game Boy Outer Case Replacement, Batteries: paso 1, imagen 2 de 2
    • Switch your Game Boy off and remove the cartridge.
  2. Game Boy Outer Case Replacement: paso 2, imagen 1 de 3 Game Boy Outer Case Replacement: paso 2, imagen 2 de 3 Game Boy Outer Case Replacement: paso 2, imagen 3 de 3
    • Use a fingernail (or small coin) to push down on the battery door latch and remove the battery door.
    • The release latch is a plastic spring clip. If your Game Boy is getting on in years, be careful as the plastic may be brittle.
    • When you're replacing the cover, be sure to get its two plastic tabs into the slots in the bottom of the battery compartment before pushing the cover back in place.
  3. Game Boy Outer Case Replacement: paso 3, imagen 1 de 2 Game Boy Outer Case Replacement: paso 3, imagen 2 de 2
    • Use a fingernail to pry each battery outward from the positive (+) terminal to remove them.
    • Dispose of used batteries properly!
    • Remove the batteries from your Game Boy before storing it for more than a month or so.
  4. Game Boy Outer Case Replacement, Outer Case: paso 4, imagen 1 de 1
    • Remove the six Triwing screws from the back of the device.
  5. Game Boy Outer Case Replacement: paso 5, imagen 1 de 1
    • Gently separate the device's front casing from the back casing after you remove the screws.
    • Be careful not to completely separate the casing halves, as they are still joined by a large ribbon cable that may be damaged.
  6. Game Boy Outer Case Replacement: paso 6, imagen 1 de 1
    • Slide the front side of the casing down to expose the ribbon cable connector.
  7. Game Boy Outer Case Replacement: paso 7, imagen 1 de 1
    • Grip the ribbon connector with your thumb and forefinger. Pull down gently until the connector, not the ribbon itself, comes out of its socket.
    • Separate the front and back casings.
Conclusión
13 personas más completaron esta guía.
Equipo
Cal Poly, Team 3-2, Johann Summer 2010 Miembro de Cal Poly, Team 3-2, Johann Summer 2010
CPSU-JOHANN-R10S3G2
3 Miembros
31 Guías creadas
2 comentarios
U need a tri-wing screwdriver not a Philips #00
radiofreeroyaloak - Contestar
It is a Philips if gb was made after 1998 or so.
Sam - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 19
Todo El Tiempo: 15,649
