Saltar al contenido principal
Game Boy Display Lines/Bars
Qué necesitas
  1. Game Boy Display Lines/Bars, Game Boy Display Lines/Bars: paso 1, imagen 1 de 3 Game Boy Display Lines/Bars, Game Boy Display Lines/Bars: paso 1, imagen 2 de 3 Game Boy Display Lines/Bars, Game Boy Display Lines/Bars: paso 1, imagen 3 de 3
    • Remove the back housing by removing the 6 Tri-Point or Philip screws.
    • Note: The last 2 screws are in the battery compartment.
  2. Game Boy Display Lines/Bars: paso 2, imagen 1 de 2 Game Boy Display Lines/Bars: paso 2, imagen 2 de 2
    • Carefully lift up the top half of the system. Be careful, there's a ribbon cable that connects the top and bottom half of the system.
    • Remove the ribbon cable for the next step.
  3. Game Boy Display Lines/Bars: paso 3, imagen 1 de 3 Game Boy Display Lines/Bars: paso 3, imagen 2 de 3 Game Boy Display Lines/Bars: paso 3, imagen 3 de 3
    • Now there will be screws that mount the board to the front, carefully unscrew these.
    • Now remove the board from the housing.
    • Now put the batteries back into the compartment, so you can test the screen while you fix it.
    • Reconnect the the board to back housing with the ribbon cable.
  4. Game Boy Display Lines/Bars: paso 4, imagen 1 de 1
    • You're now going to turn the contrast ( the slider on the left) all the way up, and take your soldering iron and gently move it back and forth on the ribbon cable below the screen.
    • Make sure not to touch the screen itself.
    • Note: There may be a rubber strip covering the ribbon.
    • You will start to see the lines of pixels fade in and out, keep moving your iron back and forth until screen is completely black.
Conclusión
6 personas más completaron esta guía.
Mitchell
Miembro Desde 04/03/16
184 Reputación
1 Guía escrita
Un comentario
Hi, this is the second time I attempt this fix, the first time it worked perfectly. The problem is that with this second machine there's a couple of pixel lines that have not tickled back to black even though I have been patiently going over them for quite some time (2 rounds of 10-15 min) is there anything else that I could try or should I just go on over the same area until I see something happen? Thanks in advance
Jose Saura - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 11
Ultimos 30 días: 42
Todo El Tiempo: 4,435
