Saltar al contenido principal
Game Boy Color Screen Cover Replacement
Qué necesitas
  1. Game Boy Color Screen Cover Replacement, Battery: paso 1, imagen 1 de 2 Game Boy Color Screen Cover Replacement, Battery: paso 1, imagen 2 de 2
    • Locate the battery compartment on the back of the Game Boy Color.
    • Push down on the tab and hinge the cover downwards and outwards to remove the battery cover.
  2. Game Boy Color Screen Cover Replacement: paso 2, imagen 1 de 1
    • Remove the batteries from the battery compartment.
  3. Game Boy Color Screen Cover Replacement, Screen Cover: paso 3, imagen 1 de 1
    • Carefully slide a razor blade under one of the corners of the screen cover.
  4. Game Boy Color Screen Cover Replacement: paso 4, imagen 1 de 1
    • Carefully lift up on the corner of the screen until you can grab the corner with your fingers.
    • Continue gently pulling up on the cover until it is fully removed.
Conclusión
24 personas más completaron esta guía.
Equipo
Cal Poly, Team 19-47, Regan Winter 2013 Miembro de Cal Poly, Team 19-47, Regan Winter 2013
CPSU-REGAN-W13S19G47
4 Miembros
56 Guías creadas
4 comentarios
bro, you mustn't to dismount the console to only remove the old lend
sdfsafas - Contestar
You only need step 7 and 8.
h027299c - Contestar
An alternative method is to in step 7 insert a small screwdriver into the hole in the front shell where the power light goes through and push off the screen enough to pry it off with your hands. Thereby avoiding this razor-near-the-screen business. You will also most likely need some alcohol (or similar) to loosen the residue leftover from the old screen.
Nick G - Contestar
Yes that's true! I've seen repair videos where they do it the way you mentioned, much less of a headache
David Hannum -
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 5
Ultimos 7 días: 40
Ultimos 30 días: 196
Todo El Tiempo: 22,018
