Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Introducción
This guide will show you how to repair the Game Boy Color's power LED. The power led glows red when the device is turned on indicating that it is receiving power.
  1. Locate the battery compartment on the back of the Game Boy Color. Push down on the tab and hinge the cover downwards and outwards to remove the battery cover.
    • Locate the battery compartment on the back of the Game Boy Color.
    • Push down on the tab and hinge the cover downwards and outwards to remove the battery cover.
  2. Remove the batteries from the battery compartment.
    • Remove the batteries from the battery compartment.
  3. Using a Y1 screwdriver, remove the six screws on the back of the device as pictured.  The bottom two screws are located inside of the battery compartment.
    • Using a Y1 screwdriver, remove the six screws on the back of the device as pictured. The bottom two screws are located inside of the battery compartment.
  4. Gently lift and separate the back housing from the rest of the device.  Now you've got the back housing out! Gently lift and separate the back housing from the rest of the device.  Now you've got the back housing out!
    • Gently lift and separate the back housing from the rest of the device. Now you've got the back housing out!
  5. SALTEA LA ACTUALIZACIÓN
    Ahorra reparando con un kit todo en uno.
    Compra Kits de Reparación
  6. Using the Phillips #1 screwdriver, remove the 3 screws shown in the picture. Using the Phillips #1 screwdriver, remove the 3 screws shown in the picture.
    • Using the Phillips #1 screwdriver, remove the 3 screws shown in the picture.
  7. Gently lift the motherboard from the front housing.
    • Gently lift the motherboard from the front housing.
  8. Unsolder and remove the LED from the circuit board. Click here for a guide on how to solder and unsolder
  9. Insert new LED into the circuit board.
    • Insert new LED into the circuit board.
    • Make sure that the LED is in the correct orientation. The longer leg of the LED is the positive end, while the shorter leg is the negative end.
    • The positive lead should go through the hole closest to the edge of the circuit board.
  10. Solder the leads of the new LED to the circuit board.
    • Solder the leads of the new LED to the circuit board.
  11. Cut the excess ends of the LED legs using the wire cutters.
    • Cut the excess ends of the LED legs using the wire cutters.
Conclusión
4 personas más completaron esta guía.
Alex Wu
Miembro Desde 11/01/13
1,021 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 19-47, Regan Winter 2013 Miembro de Cal Poly, Team 19-47, Regan Winter 2013
CPSU-REGAN-W13S19G47
4 Miembros
34 Guías creadas
what is the brass color looking thing under the soldering iron in step 7?
Soul Divide - Contestar
That's called 'Desoldering Braid', it sucks up solder like a wick
John Smith -
and what kind of LED are you using to replace?
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 31
Ultimos 30 días: 136
Todo El Tiempo: 10,119
