Saltar al contenido principal
Game Boy Color Buttons Replacement
Qué necesitas
  1. Game Boy Color Buttons Replacement, Battery: paso 1, imagen 1 de 2 Game Boy Color Buttons Replacement, Battery: paso 1, imagen 2 de 2
    • Locate the battery compartment on the back of the Game Boy Color.
    • Push down on the tab and hinge the cover downwards and outwards to remove the battery cover.
  2. Game Boy Color Buttons Replacement: paso 2, imagen 1 de 1
    • Remove the batteries from the battery compartment.
  3. Game Boy Color Buttons Replacement, Back Housing: paso 3, imagen 1 de 1
    • Using a Y1 screwdriver, remove the six screws on the back of the device as pictured. The bottom two screws are located inside of the battery compartment.
  4. Game Boy Color Buttons Replacement: paso 4, imagen 1 de 2 Game Boy Color Buttons Replacement: paso 4, imagen 2 de 2
    • Gently lift and separate the back housing from the rest of the device. Now you've got the back housing out!
  5. Game Boy Color Buttons Replacement, LCD Ribbon Cable: paso 5, imagen 1 de 1
    • Push up on the tabs on either side of the ribbon with a spudger.
  6. Game Boy Color Buttons Replacement: paso 6, imagen 1 de 1
    • Gently remove the ribbon cable from the port
  7. Game Boy Color Buttons Replacement, Motherboard: paso 7, imagen 1 de 2 Game Boy Color Buttons Replacement, Motherboard: paso 7, imagen 2 de 2
    • Using the Phillips #1 screwdriver, remove the 3 screws shown in the picture.
  8. Game Boy Color Buttons Replacement: paso 8, imagen 1 de 1
    • Gently lift the motherboard from the front housing.
  9. Game Boy Color Buttons Replacement, Buttons: paso 9, imagen 1 de 1
    • Remove the rubber backing on each button grouping.
  10. Game Boy Color Buttons Replacement: paso 10, imagen 1 de 1
    • Remove the original buttons from the housing.
Conclusión
24 personas más completaron esta guía.
Equipo
Cal Poly, Team 19-47, Regan Winter 2013 Miembro de Cal Poly, Team 19-47, Regan Winter 2013
CPSU-REGAN-W13S19G47
4 Miembros
56 Guías creadas
2 comentarios
Thank you for your information on repair of my color game boy.
just two things.
1. I had a hard time with the removal of the screws. Any tip on that would be helpful.
2. Where can I purchase replacement parts?
Thanks again for all of your help.
Ray Blasko
raymondblasko - Contestar
In the tools needed it states Y0 screwdriver, but in step 3 it says Y1 which is not the same. Which one is the correct size?
blogcraft - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 62
Ultimos 30 días: 282
Todo El Tiempo: 27,856
