Introducción
Use this repair guide in order to replace the speakers.
Herramientas
Partes
No se especificaron partes.
Take the battery cover off by releasing the locking tab and hinging the cover away.
Remove left and right triggers by lifting and pulling them away from the system.
Do the same for side panels
Remove the gray On/Off Switch by pulling up and away from the unit. Replace with another switch if necessary.
Remove the rubber button pads from their pockets.
Remove the plastic buttons and the D-pad from beneath the rubber pads with tweezers or by hand.
9 personas más completaron esta guía.
Un Comentario
When no sound in GBA. Is the broken speaker the most common problem ? Or some SMD part in circuit board ? What to do if the new replaced speaker emits no sound ?
