Saltar al contenido principal
Game Boy Advance LCD Screen Replacement
Qué necesitas
  1. Game Boy Advance LCD Screen Replacement, Remove the Battery Cover/Batteries: paso 1, imagen 1 de 3 Game Boy Advance LCD Screen Replacement, Remove the Battery Cover/Batteries: paso 1, imagen 2 de 3 Game Boy Advance LCD Screen Replacement, Remove the Battery Cover/Batteries: paso 1, imagen 3 de 3
    • Take the battery cover off by releasing the locking tab and hinging the cover away. Remove the batteries inside the cover
    • Do not forget to remove the batteries! This applies to working with any electronic device as working with live electricity may damage the device or cause malfunctions
  2. Game Boy Advance LCD Screen Replacement, Unscrew the Back Panel: paso 2, imagen 1 de 2 Game Boy Advance LCD Screen Replacement, Unscrew the Back Panel: paso 2, imagen 2 de 2
    • Remove the six back panel screws using a Tri-wing Screwdriver.
    • Remove bottom back panel screw with a Phillips #1 screw driver. (Image #2)
  3. Game Boy Advance LCD Screen Replacement, Remove the Back Panel: paso 3, imagen 1 de 1
    • Remove the back panel by pulling away with one hand and the front secured in the other hand.
    • Removal of the back panel may cause shoulder buttons and side panels to come loose and fall off.
  4. Game Boy Advance LCD Screen Replacement, Remove Triggers: paso 4, imagen 1 de 2 Game Boy Advance LCD Screen Replacement, Remove Triggers: paso 4, imagen 2 de 2
    • Remove left and right triggers by lifting and pulling them away from the system.
    • Do the same for side panels
    • For finicky or jammed triggers only! Adjust and correct triggers and reassemble. Most jammed triggers are caused by buttons misplaced or jammed in its enclosure.
  5. Game Boy Advance LCD Screen Replacement, Remove the On/Off Switch: paso 5, imagen 1 de 1
    • Remove the gray On/Off Switch by pulling up and away from the unit. Replace with another switch if necessary.
  6. Game Boy Advance LCD Screen Replacement, Buttons and LCD Screen: paso 6, imagen 1 de 1
    • Remove the three screws on the circuit board with a Phillips #1 screw driver.
  7. Game Boy Advance LCD Screen Replacement: paso 7, imagen 1 de 2 Game Boy Advance LCD Screen Replacement: paso 7, imagen 2 de 2
    • Pull circuit board away from the front panel by pulling up at the bottom of the circuit board, keeping the top ribbon still connected.
    • Handle with care! The ribbon connecting the circuit board to the LCD screen can easily be damaged and will require replacement if broken.
  8. Game Boy Advance LCD Screen Replacement, Buttons: paso 8, imagen 1 de 3 Game Boy Advance LCD Screen Replacement, Buttons: paso 8, imagen 2 de 3 Game Boy Advance LCD Screen Replacement, Buttons: paso 8, imagen 3 de 3
    Herramienta utilizada en este paso:
    Comprar
    • Remove the rubber button pads from their pockets.
    • Remove the plastic buttons and the D-pad from beneath the rubber pads with tweezers or by hand.
  9. Game Boy Advance LCD Screen Replacement, LCD Screen: paso 9, imagen 1 de 3 Game Boy Advance LCD Screen Replacement, LCD Screen: paso 9, imagen 2 de 3 Game Boy Advance LCD Screen Replacement, LCD Screen: paso 9, imagen 3 de 3
    Comprar
    • Use a spudger/tweezers/fingernail to unlatch the LCD ribbon port by pulling the grey tabs on the sides upwards (towards the top edge of the PCB).
    • Once the LCD ribbon port has been unlatched, the LCD ribbon should very easily slide out and can be removed with zero force using fingers or tweezers.
  10. Game Boy Advance LCD Screen Replacement: paso 10, imagen 1 de 3 Game Boy Advance LCD Screen Replacement: paso 10, imagen 2 de 3 Game Boy Advance LCD Screen Replacement: paso 10, imagen 3 de 3
    • Use the spudger to lift the screen from the front panel. Place the spudger in the space directly left of the D-pad.
    • The screen and the front panel is connected by a black tape that could rip if not removed carefully.
Conclusión
17 personas más completaron esta guía.
Aldo Corona
Miembro Desde 01/25/10
799 Reputación
6 Guías creadas
Equipo
Cal Poly, Team 16-29, Maness Winter 2010 Miembro de Cal Poly, Team 16-29, Maness Winter 2010
CPSU-MANESS-W10S16G29
5 Miembros
61 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 5
Ultimos 7 días: 40
Ultimos 30 días: 179
Todo El Tiempo: 25,016
