Introducción
This section describes removing the logic board whole from the case.
Herramientas
Partes
No se especificaron partes.
Take the battery cover off by releasing the locking tab and hinging the cover away.
Remove left and right triggers by lifting and pulling them away from the system.
Do the same for side panels
Remove the gray On/Off Switch by pulling up and away from the unit. Replace with another switch if necessary.
Remove the three screws on the circuit board with a Phillips #1 screw driver.
3 personas más completaron esta guía.
