Saltar al contenido principal
Game Boy Advance Back Panel Replacement
Qué necesitas
Resumen del Video
  1. Game Boy Advance Back Panel Replacement, Remove the Battery Cover/Batteries: paso 1, imagen 1 de 3 Game Boy Advance Back Panel Replacement, Remove the Battery Cover/Batteries: paso 1, imagen 2 de 3 Game Boy Advance Back Panel Replacement, Remove the Battery Cover/Batteries: paso 1, imagen 3 de 3
    • Take the battery cover off by releasing the locking tab and hinging the cover away. Remove the batteries inside the cover
    • Do not forget to remove the batteries! This applies to working with any electronic device as working with live electricity may damage the device or cause malfunctions
  2. Game Boy Advance Back Panel Replacement, Unscrew the Back Panel: paso 2, imagen 1 de 2 Game Boy Advance Back Panel Replacement, Unscrew the Back Panel: paso 2, imagen 2 de 2
    • Remove the six back panel screws using a Tri-wing Screwdriver.
    • Remove bottom back panel screw with a Phillips #1 screw driver. (Image #2)
  3. Game Boy Advance Back Panel Replacement, Remove the Back Panel: paso 3, imagen 1 de 1
    • Remove the back panel by pulling away with one hand and the front secured in the other hand.
    • Removal of the back panel may cause shoulder buttons and side panels to come loose and fall off.
Conclusión
4 personas más completaron esta guía.
Aldo Corona
Miembro Desde 01/25/10
814 Reputación
6 Guías creadas
Equipo
Cal Poly, Team 16-29, Maness Winter 2010 Miembro de Cal Poly, Team 16-29, Maness Winter 2010
CPSU-MANESS-W10S16G29
5 Miembros
62 Guías creadas
Un comentario
Seeing the GBA-SP guide, could information here be added so we know which mm triwing screws the regular GBA backpanel uses?
Renzo Guichelaar - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 16
Ultimos 30 días: 62
Todo El Tiempo: 11,277
