Saltar al contenido principal
Galaxy Tab S 10.5 Camera Replacement
Qué necesitas
  1. Galaxy Tab S 10.5 Camera Replacement, Disassembling Galaxy Tab S 10.5 Back Cover: paso 1, imagen 1 de 2 Galaxy Tab S 10.5 Camera Replacement, Disassembling Galaxy Tab S 10.5 Back Cover: paso 1, imagen 2 de 2
    • Place the plastic opening tool into the SD card slot or charge port.
    • Try in an upward motion until you see a separation between the tablet and back cover.
  2. Galaxy Tab S 10.5 Camera Replacement: paso 2, imagen 1 de 1
    • Work around the entire device by sliding the plastic opening tool around the rim.
    • If this is the first time, it will be hard to separate the back cover from the tablet.
    • The clips are approximately 5 cm apart. While working around the device, the clips will make a dislocating sound when disconnected.
  3. Galaxy Tab S 10.5 Camera Replacement: paso 3, imagen 1 de 1
    • Remove the back cover once all links have been separated.
    • Be careful when touching any of the internal components of the tablet.
  4. Galaxy Tab S 10.5 Camera Replacement, Camera: paso 4, imagen 1 de 3 Galaxy Tab S 10.5 Camera Replacement, Camera: paso 4, imagen 2 de 3 Galaxy Tab S 10.5 Camera Replacement, Camera: paso 4, imagen 3 de 3
    • Use a spudger to disconnect the camera from the motherboard and then remove the camera.
Conclusión
Una persona más ha completado esta guía.
Jordan Soto
Miembro Desde 08/26/15
3,249 Reputación
6 Guías creadas
Equipo
USF Tampa, Team 3-2, Eyestone Fall 2015 Miembro de USF Tampa, Team 3-2, Eyestone Fall 2015
USFT-EYESTONE-F15S3G2
3 Miembros
20 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 6
Ultimos 30 días: 13
Todo El Tiempo: 2,534
