Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Resumen del Video
Este desmontaje no es una guía de reparación. Para reparar tu Galaxy S23 Ultra, utiliza nuestros manuales de servicio .
  1. Galaxy S23 Ultra Chip ID, Main Board Side 1: paso 1, imagen 1 de 2 Galaxy S23 Ultra Chip ID, Main Board Side 1: paso 1, imagen 2 de 2
    • Qualcomm SM8550 64-bit octa-core Snapdragon applications/baseband processor layered underneath Micron MT62F1536M64D8CL-026 WT:B 12 GB LPDDR5 SDRAM memory
    • Samsung KLUFG8RHHD-B0G1 512 GB NAND flash memory w/ controller
    • Wacom WEZ02 digitizer controller
    • Cirrus Logic CS35L42 audio amplifier
    • Cirrus Logic CS40L26 haptic driver
    • Analog Devices MAX77705C power management
    • NXP Semiconductor PCA9481UK battery charger
  2. Galaxy S23 Ultra Chip ID: paso 2, imagen 1 de 1
    • Silicon Mitus SM3080I power management
    • Samsung S2MPBA3 power management
    • ConvenientPower CPS4038 40 W wireless power receiver w/ 10 W wireless power transmitter
    • Possibly Qualcomm envelope tracking power supply
    • Knowles MEMS microphone
    • Possibly Qualcomm power management
    • Possibly NXP Semiconductor load switch
  3. Galaxy S23 Ultra Chip ID, Main Board Side 1 - Connectivity: paso 3, imagen 1 de 1
    • Qualcomm WCN7851-101 FastConnect 7800 WiFi 7, 6, & 6E & Bluetooth 5.3 transceiver
    • NXP Semiconductor SR200T ? ultra-wideband transceiver
    • Qualcomm SDR735-001 RF transceiver
    • Qualcomm SMR546-002 RF transceiver
    • NXP Semiconductor SN220U ? NFC controller w/ secure element
  4. Galaxy S23 Ultra Chip ID, Main Board Side 1 - Sensors: paso 4, imagen 1 de 1
    • AMS TMD4913 ? color & proximity sensor
    • STMicroelectronics LSM6DSO 6-axis accelerometer/gyroscope
    • STMicroelectronics LPS22HH pressure sensor
  5. Galaxy S23 Ultra Chip ID, Main Board Side 2: paso 5, imagen 1 de 1
    • STMicroelectronics STM32G051 ? 32-bit microcontroller
    • Qualcomm PMK8550 ? clock generator
    • Qualcomm PM8550VE-001 power management
    • Qualcomm PM8550VS-001 power management
    • Samsung S2MPB02 power management
    • Goertek MEMS Microphone
  6. Galaxy S23 Ultra Chip ID: paso 6, imagen 1 de 1
    • Qualcomm power management
    • ETEK Microelectronics ET9902 over-voltage & surge protection
    • Kinetic Technologies over-voltage protection ?
    • NXP Semiconductor NVT4557HK SIM card interface level translator
    • Vishay DG2730 2-port DPDT analog switch
    • Diodes Incorporated AP7340D-30FS4-7 150 mA / 3.0 V LDO regulator
  7. Galaxy S23 Ultra Chip ID, Main Board Side 2 - Connectivity: paso 7, imagen 1 de 1
    • Qualcomm QPM7815-005 front end module
    • Qualcomm QPM6810-003 front end module
    • Maxscend MXDLN16GE GPS/GLONASS/Galileo/BeiDou low noise amplifier
    • Infineon BGSA20UGL8 dual SPST RF switch
  8. Galaxy S23 Ultra Chip ID, Main Board Side 2 - Sensors: paso 8, imagen 1 de 1
    • AKM Semiconductor AK09918C electronic compass
  9. Galaxy S23 Ultra Chip ID, Main Board Side 2 - Filters: paso 9, imagen 1 de 1
  10. Galaxy S23 Ultra Chip ID, Charging Port Board Side 1: paso 10, imagen 1 de 2 Galaxy S23 Ultra Chip ID, Charging Port Board Side 1: paso 10, imagen 2 de 2
    • Diodes Incorporated AH1897T ? hall sensor
    • Probably antenna switch
  11. Galaxy S23 Ultra Chip ID, Charging Port Board Side 2: paso 11, imagen 1 de 2 Galaxy S23 Ultra Chip ID, Charging Port Board Side 2: paso 11, imagen 2 de 2
    • Wisol antenna switch module
    • Qualcomm antenna tuner
  12. Galaxy S23 Ultra Chip ID, Display Flex: paso 12, imagen 1 de 2 Galaxy S23 Ultra Chip ID, Display Flex: paso 12, imagen 2 de 2
    • STMicroelectronics FJACJ ? touchscreen controller
    • Winbond W25Q80EWUXIE 1 MB serial NOR flash memory
    • Qualcomm QFS2630 ultrasonic fingerprint sensor
    • Qualcomm QBT2600-100 fingerprint sensor controller
9Guía Comentarios
The fact that Samsung have been using the same audio amplifiers since the S10, blows my mind. So the big step up in speakers on the S23 series is purely down to the new AAC SLS speaker partnership and some dsp optimisation.
djlobb01 - Contestar Compartir
Correction: The S22 and prior use the CS35L40, while the S23 is using a seemingly customised part (CS35L42), there doesn't appear to be any kind of specs sheets available so I'm not sure if it's comparable to the CS35L45 in some of the other phones like the ROG, BlackShark, Xiaomi which have phenomenal sound systems.
is the Qualcomm WCN7851-101 FastConnect 7800 available worldwide or in US models only
Hossam El-Din Yasser - Contestar Compartir
Where is the camera hardware located?
Lotus Flower - Contestar Compartir
Wasn't the S23 Ultra supposed to have LPDDR5x RAM?
Marcel Vos - Contestar Compartir
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 22
Ultimos 7 días: 147
Ultimos 30 días: 732
Todo El Tiempo: 50,761
