Saltar al contenido principal
Galaxy J3 Prime LCD Screen Replacement
Qué necesitas
Resumen del Video
    • Remove the back cover and battery.
    • Heat up the screen to loosen the adhesive.
    • You can use a iOpener or a hair drier, but make sure you don't get the phone too hot.
    • Put a spudger between the phone frame and the front display.
    • Remove the plastic bracket that will be visible when you pry up the screen.
    • Gently pull up on the LCD screen adhesive to remove the screen.
    • Remove the screws on the back of the phone frame that are holding the housing of the phone together.
    • Now that all of the screws have been removed, pull up the frame with a screwdriver or spudger.
    • Be gentle so you don't break anything.
    • Disconnect the metal flex cable from the charging port.
    • Remove the Motherboard from the housing.
Conclusión
9 personas más completaron esta guía.
Brian Brown
Miembro Desde 09/26/16
393 Reputación
1 Guía escrita
3Guía Comentarios
great guide, this really helped
anonymous 591 - Contestar
thanks for your help, this has really helped
Marvinhenderson4@gmail.com - Contestar
Best guide for a J3 out there professional and easy to follow
Keith Pobuta - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 34
Todo El Tiempo: 7,105
