Introducción
This is a simple GUESS watch battery replacement guide. Watches lose energy after extended usage, however this does not mean you need to purchase a new watch. Just changing the battery will restore the time and watch you need. It requires no prior expertise and takes about 8 minutes to complete from start to end. This replacement takes only two tools: tweezers and a flat head screwdriver. After following the steps in the guide, to finish the job just repeat the steps in reverse order. Take caution while handling your watch because the tools you're using might easily scratch it. If a new battery is required, here is a link to one.
Qué necesitas
Una persona más ha completado esta guía.
