Introducción
GPD WIN is a very good game console.
However, I was so absorbed in it that the controller got messed up.
At this rate, you will not be able to perform any tricks or reload!
Replace the silicone pad immediately
Qué necesitas
There is a small space beside the keyboard, insert the pick and remove the claw
As you open the device, you can see that the flexible cable and the battery cable are connected. Then unplug the connector.
Remove screws on the logic board.
Because some black threads are mixed, do not forget to remove
Remove Wi-Fi antenna cable and LCD connector
Remove the screws of the joystick and remove the flex cable from the connector.
Then, it is ready to pull logic board out of the case.
You can access the silicone pad by removing the logic board.
Replace a sticky silicon pad
To reassemble your device, please follow these steps in reverse order.
Una persona más ha completado esta guía.
Un agradecimiento especial a estos traductores:
100%
Estos traductores nos están ayudando a reparar el mundo! ¿Quieres contribuir?
Empezar a traducir ›
