Saltar al contenido principal
GE TrueTemp Oven Light Bulb Replacement
Qué necesitas
  1. GE TrueTemp Oven Light Bulb Replacement, Light Bulb: paso 1, imagen 1 de 1
    • Unplug the power cord from the wall outlet for safety purposes.
  2. GE TrueTemp Oven Light Bulb Replacement: paso 2, imagen 1 de 1
    • Open the oven door and locate the oven light placement (located on the back wall, in upper left corner for this specific model.)
  3. GE TrueTemp Oven Light Bulb Replacement: paso 3, imagen 1 de 1
    • Locate the metal strap holding the glass cover over the bulb.
  4. GE TrueTemp Oven Light Bulb Replacement: paso 4, imagen 1 de 1
    • Slide the strap to the side to free the glass casing.
  5. GE TrueTemp Oven Light Bulb Replacement: paso 5, imagen 1 de 1
    • View the light bulb without the glass case and ensure there is nothing else securing it to the oven.
    • Check to make sure there is no debris around the bulb and that the light bulb is ready to be removed.
  6. GE TrueTemp Oven Light Bulb Replacement: paso 6, imagen 1 de 1
    • Using a dry cloth or gloves, unscrew the light bulb by turning it in a counter clockwise motion.
  7. GE TrueTemp Oven Light Bulb Replacement: paso 7, imagen 1 de 2 GE TrueTemp Oven Light Bulb Replacement: paso 7, imagen 2 de 2
    • Screw in new light bulb in the clock wise direction.
  8. GE TrueTemp Oven Light Bulb Replacement: paso 8, imagen 1 de 1
    • Replace the glass cover over the bulb, but be sure to hold on to it tightly.
  9. GE TrueTemp Oven Light Bulb Replacement: paso 9, imagen 1 de 1
    • Secure the glass case to the oven with the metal strap by sliding it back over case until it fits tightly.
  10. GE TrueTemp Oven Light Bulb Replacement: paso 10, imagen 1 de 1
    • Plug the oven power cord back into power source.
  11. GE TrueTemp Oven Light Bulb Replacement: paso 11, imagen 1 de 1
    • Press the button for oven light to come on.
  12. GE TrueTemp Oven Light Bulb Replacement: paso 12, imagen 1 de 1
    • View light to ensure the replacement was successful.
Linea de Meta
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 6
Ultimos 7 días: 51
Ultimos 30 días: 162
Todo El Tiempo: 17,343
