Saltar al contenido principal
GE TBX16JABWW Light Bulb Replacement
Qué necesitas
  1. GE TBX16JABWW Light Bulb Replacement, Light Bulb: paso 1, imagen 1 de 3 GE TBX16JABWW Light Bulb Replacement, Light Bulb: paso 1, imagen 2 de 3 GE TBX16JABWW Light Bulb Replacement, Light Bulb: paso 1, imagen 3 de 3
    • Put on a set of nitrile or latex gloves.
    • Move the refrigerator forward, to access the electrical plug.
    • Behind the refrigerator, unplug the cord from the electrical outlet.
  2. GE TBX16JABWW Light Bulb Replacement: paso 2, imagen 1 de 2 GE TBX16JABWW Light Bulb Replacement: paso 2, imagen 2 de 2
    • Open the refrigerator, locate the light bulb to be replaced.
    • Unscrew the light bulb counterclockwise (to the left), to remove.
    • Caution: Using too much pressure or force can break the light bulb, resulting in broken glass.
    • Dispose of the old light bulb properly and grab a new light bulb.
  3. GE TBX16JABWW Light Bulb Replacement: paso 3, imagen 1 de 3 GE TBX16JABWW Light Bulb Replacement: paso 3, imagen 2 de 3 GE TBX16JABWW Light Bulb Replacement: paso 3, imagen 3 de 3
    • To install a new light bulb, screw clockwise (to the right) to tighten in place.
    • Behind the refrigerator, plug the cord back into the electrical outlet.
  4. GE TBX16JABWW Light Bulb Replacement: paso 4, imagen 1 de 2 GE TBX16JABWW Light Bulb Replacement: paso 4, imagen 2 de 2
    • Open the refrigerator, check to make sure the light bulb turns on with no issues.
    • Move the refrigerator back into place.
Linea de Meta
Arnold Rodriguez
Miembro Desde 10/26/22
109 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 8
Todo El Tiempo: 267
