Saltar al contenido principal
GE Carescape R860 Alarm Light (PWA) Board Replacement
Equipo médico
El fabricante de este equipo médico no ha avalado o contratado a iFixit ni a esta guía de reparación.
Qué necesitas
  1. GE Carescape R860 Alarm Light (PWA) Board Replacement, GE Carescape R860 Display Unit Disassembly: paso 1, imagen 1 de 1
    • Using an opening tool, gently pry the alarm light lens (boxed) from the display unit.
  2. GE Carescape R860 Alarm Light (PWA) Board Replacement: paso 2, imagen 1 de 1
    • Loosen the seven screws that hold the rear housing using a Phillips #0 screwdriver.
    • Remove the rear housing.
  3. GE Carescape R860 Alarm Light (PWA) Board Replacement: paso 3, imagen 1 de 1
    • Cut the cable tie holding the two cables at the lower right side using scissors.
  4. GE Carescape R860 Alarm Light (PWA) Board Replacement: paso 4, imagen 1 de 1
    • Disconnect the touch controller cable.
  5. GE Carescape R860 Alarm Light (PWA) Board Replacement: paso 5, imagen 1 de 1
    • Disconnect the Keypad harness at the Carrier Board.
  6. GE Carescape R860 Alarm Light (PWA) Board Replacement: paso 6, imagen 1 de 1
    • Disconnect the encoder harness from the Carrier Board.
  7. GE Carescape R860 Alarm Light (PWA) Board Replacement: paso 7, imagen 1 de 1
    • Disconnect the speaker harness from the Carrier Board and set the speakers aside.
  8. GE Carescape R860 Alarm Light (PWA) Board Replacement: paso 8, imagen 1 de 1
    • Disconnect the alarm light harness from the Carrier Board.
  9. GE Carescape R860 Alarm Light (PWA) Board Replacement: paso 9, imagen 1 de 1
    • Loosen (do not remove) the five screws at the top edge of the shield just enough to raise it and slide the shield away with a Phillips #0 screwdriver.
  10. GE Carescape R860 Alarm Light (PWA) Board Replacement: paso 10, imagen 1 de 1
    • Loosen the four screws along each side of the shield with a Phillips #0 screwdriver.
  11. GE Carescape R860 Alarm Light (PWA) Board Replacement: paso 11, imagen 1 de 1
    • Remove the four screws at the bottom edge of the shield with a Phillips #0 screwdriver.
  12. GE Carescape R860 Alarm Light (PWA) Board Replacement: paso 12, imagen 1 de 1
    • Slide the shield down to disengage the touch controller harness connector.
  13. GE Carescape R860 Alarm Light (PWA) Board Replacement, Alarm Light (PWA) Board: paso 13, imagen 1 de 1
    • Pull the PWA board from the slot.
    • Replace the PWA board.
  14. GE Carescape R860 Alarm Light (PWA) Board Replacement: paso 14, imagen 1 de 1
    • Reconnect the alarm light harness.
Conclusión
Andre Fisher
Miembro Desde 01/23/20
357 Reputación
2 Guías creadas
Equipo
Cal Poly, Team S7-G9, Paton Spring 2020 Miembro de Cal Poly, Team S7-G9, Paton Spring 2020
CPSU-PATON-S20S7G9
3 Miembros
4 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 7
Todo El Tiempo: 271
