Introducción
If the motor of your laminator is not working, it may need to be replaced. Since the motor is inside of the device, you need to disassemble the Laminator. For this guide, you will need to open the top of the device using a Phillips #2 screwdriver to remove the screws. It is not difficult to open the laminator, but some of the components may be difficult to pull apart.
Qué necesitas
Using the Phillips #2 screwdriver, remove ten 12 mm long screws on the bottom of the device.
Una persona más ha completado esta guía.
