Saltar al contenido principal
GBC Creative Laminator Gear Replacement
Qué necesitas
  1. GBC Creative Laminator Gear Replacement, Gear: paso 1, imagen 1 de 2 GBC Creative Laminator Gear Replacement, Gear: paso 1, imagen 2 de 2
    • Using the Phillips #2 screwdriver, remove ten 12 mm long screws on the bottom of the device.
  2. GBC Creative Laminator Gear Replacement: paso 2, imagen 1 de 1
    • Open the top of the device, and the inside of the Laminator will be exposed as shown.
  3. GBC Creative Laminator Gear Replacement: paso 3, imagen 1 de 3 GBC Creative Laminator Gear Replacement: paso 3, imagen 2 de 3 GBC Creative Laminator Gear Replacement: paso 3, imagen 3 de 3
    • Using the Phillips #2 screwdriver, remove the two 9 mm long screws on the side of the main component that fix the motor in place.
    • Pull the motor off of the main internal component to reveal the gear.
  4. GBC Creative Laminator Gear Replacement: paso 4, imagen 1 de 1
    • Pull the gear off of the motor.
Conclusión
4 personas más completaron esta guía.
Yujia Tang
Miembro Desde 07/11/18
384 Reputación
2 Guías creadas
Equipo
IUPUI, Team S1-G1, Wilson Summer 2018 Miembro de IUPUI, Team S1-G1, Wilson Summer 2018
IUPUI-WILSON-SU18S1G1
5 Miembros
4 Guías creadas
Un comentario
Can you tell me where I might find a replacement gear for my GBC H200? I would like to find a brass gear but mine melted and need to find a replacement but no info for the gear. I think it is 17 teeth but not sure about the rest.
Jim Pruitt - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 17
Ultimos 30 días: 66
Todo El Tiempo: 3,368
