Saltar al contenido principal
GATEWAY NE56R09u RAM Replacement
Qué necesitas
  1. GATEWAY NE56R09u RAM Replacement, Battery: paso 1, imagen 1 de 1
    • Before doing anything, first make sure the laptop is turned off and flipped over. In this position your laptop's bottom side should be facing up.
  2. GATEWAY NE56R09u RAM Replacement: paso 2, imagen 1 de 1
    • Using a nylon spudger or your fingers, push down on the battery clip to release the battery.
  3. GATEWAY NE56R09u RAM Replacement: paso 3, imagen 1 de 1
    • Finally, remove the battery by detaching it from the laptop casing. Once removed, set the battery aside and insert the new battery.
  4. GATEWAY NE56R09u RAM Replacement, RAM: paso 4, imagen 1 de 1
    • Locate the casing that protects the RAM modules, wireless card, and hard drive.
  5. GATEWAY NE56R09u RAM Replacement: paso 5, imagen 1 de 1
    • With the PH1 head from the tool kit and the adjustable screwdriver, remove the 2 M3x5.0mm screws on the casing to get to the RAM modules.
  6. GATEWAY NE56R09u RAM Replacement: paso 6, imagen 1 de 1
    • On each RAM module there are two silver latches holding them in place
    • Release the latches to be able to remove the RAM module.
  7. GATEWAY NE56R09u RAM Replacement: paso 7, imagen 1 de 1
    • Remove the RAM modules from their respected slots.
Conclusión
To reassemble your device, please follow these instructions in reverse order.
joshua depina
Miembro Desde 03/25/19
401 Reputación
3 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 10
Todo El Tiempo: 218
