Saltar al contenido principal
GATEWAY NE56R09u Battery Replacement
Qué necesitas
  1. GATEWAY NE56R09u Battery Replacement, Battery: paso 1, imagen 1 de 1
    • Before doing anything, first make sure the laptop is turned off and flipped over. In this position your laptop's bottom side should be facing up.
  2. GATEWAY NE56R09u Battery Replacement: paso 2, imagen 1 de 1
    • Using a nylon spudger or your fingers, push down on the battery clip to release the battery.
  3. GATEWAY NE56R09u Battery Replacement: paso 3, imagen 1 de 1
    • Finally, remove the battery by detaching it from the laptop casing. Once removed, set the battery aside and insert the new battery.
Conclusión
To insert the new battery, follow these instructions in reverse order.
joshua depina
Miembro Desde 03/25/19
401 Reputación
3 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 7
Todo El Tiempo: 191
