Saltar al contenido principal
GATEWAY NE56R09u Wireless Card Replacement
Qué necesitas
  1. GATEWAY NE56R09u  Wireless Card Replacement, Battery: paso 1, imagen 1 de 1
    • Before doing anything, first make sure the laptop is turned off and flipped over. In this position your laptop's bottom side should be facing up.
  2. GATEWAY NE56R09u  Wireless Card Replacement: paso 2, imagen 1 de 1
    • Using a nylon spudger or your fingers, push down on the battery clip to release the battery.
  3. GATEWAY NE56R09u  Wireless Card Replacement: paso 3, imagen 1 de 1
    • Finally, remove the battery by detaching it from the laptop casing. Once removed, set the battery aside and insert the new battery.
  4. GATEWAY NE56R09u  Wireless Card Replacement, Wireless card: paso 4, imagen 1 de 1
    • Next, using the PH1 head from the tool kit and the adjustable screwdriver, remove the 2 M3x5.0mm screws on the casing to get to the wireless card.
  5. GATEWAY NE56R09u  Wireless Card Replacement: paso 5, imagen 1 de 1
    • Once the cover is off, locate the wireless card.
  6. GATEWAY NE56R09u  Wireless Card Replacement: paso 6, imagen 1 de 1
    • When located, remove the black and white cables from the wireless card. These are main and auxiliary antenna câbles.
  7. GATEWAY NE56R09u  Wireless Card Replacement: paso 7, imagen 1 de 1
    • Using the PH1 head from the tool kit and the adjustable screwdriver, remove the M3x5.0mm screw with that is keeping the wireless card intact.
  8. GATEWAY NE56R09u  Wireless Card Replacement: paso 8, imagen 1 de 2 GATEWAY NE56R09u  Wireless Card Replacement: paso 8, imagen 2 de 2
    • Remove the wireless card from the laptop
Conclusión
To reassemble your device, please follow these instructions in reverse order.
Luis Cardoso
Miembro Desde 04/01/19
171 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 4
Todo El Tiempo: 232
