Introducción
The wireless card is a key factor for your everyday laptop use. This wireless card is refereed to as a NIC or Network Interface Card it is square in shape, and is located in the middle section in the back of the laptop where the memory cards and hard drive both are. Also, before attempting to do a replacement, make sure your device is powered off and make sure to read through the guide first before jumping straight into a repair. Safety is always first!
Qué necesitas
Before doing anything, first make sure the laptop is turned off and flipped over. In this position your laptop's bottom side should be facing up.
Next, using the PH1 head from the tool kit and the adjustable screwdriver, remove the 2 M3x5.0mm screws on the casing to get to the wireless card.
To reassemble your device, please follow these instructions in reverse order.
