Saltar al contenido principal
GATEWAY ML6720 Wireless Card Replacement
Qué necesitas
  1. GATEWAY ML6720 Wireless Card Replacement, Wireless Card: paso 1, imagen 1 de 1
    • Flip the laptop upside-down.
  2. GATEWAY ML6720 Wireless Card Replacement: paso 2, imagen 1 de 2 GATEWAY ML6720 Wireless Card Replacement: paso 2, imagen 2 de 2
    • Locate the wireless card cover, found on the middle-left section of the laptop as shown.
  3. GATEWAY ML6720 Wireless Card Replacement: paso 3, imagen 1 de 2 GATEWAY ML6720 Wireless Card Replacement: paso 3, imagen 2 de 2
    • Using the 1.5 mm Flathead Screwdriver, remove the cover screw at the top of the wireless card's cover plate.
  4. GATEWAY ML6720 Wireless Card Replacement: paso 4, imagen 1 de 1
    • Pull the wireless card's cover plate up and off to reveal the card as shown.
  5. GATEWAY ML6720 Wireless Card Replacement: paso 5, imagen 1 de 1
    • Remove the two wires connected to the wireless card.
  6. GATEWAY ML6720 Wireless Card Replacement: paso 6, imagen 1 de 2 GATEWAY ML6720 Wireless Card Replacement: paso 6, imagen 2 de 2
    Herramienta utilizada en este paso:
    Flathead 1.5 mm Screwdriver
    $5.49
    • Using the 1.5 mm Flathead Screwdriver, remove the two screws at the top left and right corners of the wireless card.
    • Slide the wireless card up and out of the compartment.
Conclusión
Nathan Da Silva
Miembro Desde 10/19/16
401 Reputación
4 Guías creadas
Equipo
UMass Dartmouth, Team 2-3, Isaacson Fall 2016 Miembro de UMass Dartmouth, Team 2-3, Isaacson Fall 2016
UMASSD-ISAACSON-F16S2G3
2 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 5
Todo El Tiempo: 268
