Saltar al contenido principal
GATEWAY ML6720 Battery Replacement
Qué necesitas
    • Flip the laptop on to the backside.
  1. GATEWAY ML6720 Battery Replacement: paso 2, imagen 1 de 1
    • Locate the battery at the very top on the backside of the laptop.
  2. GATEWAY ML6720 Battery Replacement: paso 3, imagen 1 de 2 GATEWAY ML6720 Battery Replacement: paso 3, imagen 2 de 2
    • Slide the latch in the top right corner to the right, to set it to unlocked.
  3. GATEWAY ML6720 Battery Replacement: paso 4, imagen 1 de 2 GATEWAY ML6720 Battery Replacement: paso 4, imagen 2 de 2
    • Hold the other latch in the top left corner to the left.
    • Hold it in that place with your thumb until the completion of the next step. (This step unlocks the second latch.)
  4. GATEWAY ML6720 Battery Replacement: paso 5, imagen 1 de 2 GATEWAY ML6720 Battery Replacement: paso 5, imagen 2 de 2
    • With both latches unlocked you can now slide out the battery, by pushing it off the top.
Conclusión
Nathan Da Silva
Miembro Desde 10/19/16
401 Reputación
4 Guías creadas
Equipo
UMass Dartmouth, Team 2-3, Isaacson Fall 2016 Miembro de UMass Dartmouth, Team 2-3, Isaacson Fall 2016
UMASSD-ISAACSON-F16S2G3
2 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 10
Todo El Tiempo: 310
