1. Turn locking device on back side of phone marked by the rectangle counter clockwise.
    • Turn locking device on back side of phone marked by the rectangle counter clockwise.
    Agregar Comentario
  2. Remove battery by grabbing the sides and pulling upward.
    • Remove battery by grabbing the sides and pulling upward.
    • If battery was malfunctioning due to age or corrosion, there may be battery acid residue on the battery and the back of the phone. Wear gloves in order to prevent skin irritation.
    Agregar Comentario
  3. Reparte el espíritu de reparación esta Navidad
    Obtén $12 de descuento en tu compra de $50 o más con el código FIXMAS12
    • Remove back cover by taking out the four, five point star screws indicated in the picture. A 1.5mm flathead screwdriver can be used to remove the screws.
    • Once all screws are removed the case will easily lift off.
    Agregar Comentario
    • With the back cover removed, the antenna is now exposed. To remove it, take out the phillips screw holding it in place.
    Agregar Comentario
    • With screw removed, gently pull the antenna outward. It should slide out easily.
    Agregar Comentario
Conclusión
troy
Miembro Desde 11/03/13
1 Reputación
2 Guías creadas
Equipo
Clemson, Team 13-3, Benson Spring 2013 Miembro de Clemson, Team 13-3, Benson Spring 2013
CLEM-BENSON-S13S13G3
3 Miembros
14 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 1
Últimos 7 Días: 1
Últimos 30 Días: 4
Todo El Tiempo: 355
