Saltar al contenido principal
Fusion5 5.5 Gen II Motherboard Replacement
Qué necesitas
  1. Fusion5 5.5 Gen II Motherboard Replacement, Back Cover: paso 1, imagen 1 de 2 Fusion5 5.5 Gen II Motherboard Replacement, Back Cover: paso 1, imagen 2 de 2
    • Hold the device with the screen facing away from you and the back of the device facing you.
    • Locate the groove at the bottom corner of the device.
    • Begin prying the back cover of the device off from the groove and working your way around the outside edges of the device.
  2. Fusion5 5.5 Gen II Motherboard Replacement, Midframe: paso 2, imagen 1 de 2 Fusion5 5.5 Gen II Motherboard Replacement, Midframe: paso 2, imagen 2 de 2
    • Remove thirteen 3mm Phillips #00 screws from the midframe.
    • Remove the single 5mm Phillips #0 screw below the camera.
  3. Fusion5 5.5 Gen II Motherboard Replacement: paso 3, imagen 1 de 2 Fusion5 5.5 Gen II Motherboard Replacement: paso 3, imagen 2 de 2
    • Using an opening pick, begin prying one of the top corners to remove the midframe from the device.
    • Be careful not to damage the cables inside the device when you pry the midframe off.
  4. Fusion5 5.5 Gen II Motherboard Replacement, Motherboard: paso 4, imagen 1 de 1
    Herramienta utilizada en este paso:
    Comprar
    • Using tweezers, flip the brown tab securing the ribbon cable.
    • Make sure to only lift the flap and not the connector socket due to its susceptibility to break off.
    • Grab the ribbon cable with the tweezers and pull it from its socket on the motherboard.
  5. Fusion5 5.5 Gen II Motherboard Replacement: paso 5, imagen 1 de 1
    • Remove the two 3mm Phillips #00 screws from the motherboard.
  6. Fusion5 5.5 Gen II Motherboard Replacement: paso 6, imagen 1 de 1
    • Grab the motherboard from the right edges.
    • Flip the motherboard to the left side of the device.
    • Be careful not to tear the cables attached to the motherboard as you flip the motherboard.
    • Desolder the red and blue wires to remove the motherboard from the device.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 11
Todo El Tiempo: 339
