Saltar al contenido principal
Fused LED Light Replacement
Qué necesitas
  1. Fused LED Light Replacement, Fused LED Light: paso 1, imagen 1 de 2 Fused LED Light Replacement, Fused LED Light: paso 1, imagen 2 de 2
    • Remove the upper semi-sphere diffuser by twisting or applying some heat with a heat gun or dryer to soften the adhesive.
  2. Fused LED Light Replacement: paso 2, imagen 1 de 3 Fused LED Light Replacement: paso 2, imagen 2 de 3 Fused LED Light Replacement: paso 2, imagen 3 de 3
    • Use a battery or a cell with connecting wires and apply them to the exposed solder ends on each LED.
    • The LED which doesn't lights up is detected as the faulty LED.
  3. Fused LED Light Replacement: paso 3, imagen 1 de 1
    • Using a knife or screwdriver, remove the faulty LED.
    • We need to replace it with a similar LED or a resistor.
    • Connecting the terminals directly can result in an increased current and multiple LED failure.
  4. Fused LED Light Replacement: paso 4, imagen 1 de 2 Fused LED Light Replacement: paso 4, imagen 2 de 2
    • Using the soldering iron solder an LED or a 100Ω (2W or 5W) resistor into the faulty LED space.
  5. Fused LED Light Replacement: paso 5, imagen 1 de 1
    • Connect the bulb to a power source to detect if it's working.
  6. Fused LED Light Replacement: paso 6, imagen 1 de 2 Fused LED Light Replacement: paso 6, imagen 2 de 2
    • Finally, twist the light-diffusing dome back on the light bulb.
Conclusión
4 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 6
Ultimos 7 días: 41
Ultimos 30 días: 154
Todo El Tiempo: 6,713
