Saltar al contenido principal
Furbo Dog Camera USB Power Jack Replacement
Qué necesitas
  1. Furbo Dog Camera USB Power Jack Replacement, Back Cover: paso 1, imagen 1 de 2 Furbo Dog Camera USB Power Jack Replacement, Back Cover: paso 1, imagen 2 de 2
    • Remove the lid from the top of your Furbo Dog Camera.
  2. Furbo Dog Camera USB Power Jack Replacement: paso 2, imagen 1 de 3 Furbo Dog Camera USB Power Jack Replacement: paso 2, imagen 2 de 3 Furbo Dog Camera USB Power Jack Replacement: paso 2, imagen 3 de 3
    • Rotate your Furbo so that the bottom faces you.
    • Remove the rubber caps to reveal the four screws on the bottom of the Furbo.
  3. Furbo Dog Camera USB Power Jack Replacement: paso 3, imagen 1 de 3 Furbo Dog Camera USB Power Jack Replacement: paso 3, imagen 2 de 3 Furbo Dog Camera USB Power Jack Replacement: paso 3, imagen 3 de 3
    Herramienta utilizada en este paso:
    Flathead 3/32" or 2.5 mm Screwdriver
    $5.49
    Comprar
    • Use a 2.5 mm Flathead screwdriver to remove the four 5 mm screws from the bottom of the Furbo.
    • Use a 2.5 mm Flathead screwdriver to remove the single 5 mm screw under the silver sticker.
  4. Furbo Dog Camera USB Power Jack Replacement: paso 4, imagen 1 de 3 Furbo Dog Camera USB Power Jack Replacement: paso 4, imagen 2 de 3 Furbo Dog Camera USB Power Jack Replacement: paso 4, imagen 3 de 3
    • Rotate your Furbo so that the side is facing towards you.
    • Use an opening tool to separate the two plastic coverings.
  5. Furbo Dog Camera USB Power Jack Replacement: paso 5, imagen 1 de 2 Furbo Dog Camera USB Power Jack Replacement: paso 5, imagen 2 de 2
    • Once you have separated the two plastic coverings, remove one side by pulling on it and carefully separating it from the adhesive.
  6. Furbo Dog Camera USB Power Jack Replacement, USB Power Jack: paso 6, imagen 1 de 2 Furbo Dog Camera USB Power Jack Replacement, USB Power Jack: paso 6, imagen 2 de 2
    • Use a Phillips #000 screwdriver to remove the two 5 mm screws from the USB power jack.
  7. Furbo Dog Camera USB Power Jack Replacement: paso 7, imagen 1 de 2 Furbo Dog Camera USB Power Jack Replacement: paso 7, imagen 2 de 2
    • Once you have removed the screws, gently pull the bundled cable connector free from the motherboard.
  8. Furbo Dog Camera USB Power Jack Replacement: paso 8, imagen 1 de 3 Furbo Dog Camera USB Power Jack Replacement: paso 8, imagen 2 de 3 Furbo Dog Camera USB Power Jack Replacement: paso 8, imagen 3 de 3
    • The USB power jack PCB can now be removed from your Furbo and replaced.
Linea de Meta
Una persona más ha completado esta guía.
Un comentario
Where can you find a replacement
Brandon Alves - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 5
Ultimos 7 días: 11
Ultimos 30 días: 45
Todo El Tiempo: 1,233
