Saltar al contenido principal
Furbo Dog Camera Barking Sensor Assembly Replacement
Qué necesitas
  1. Furbo Dog Camera Barking Sensor Assembly Replacement, Back Cover: paso 1, imagen 1 de 2 Furbo Dog Camera Barking Sensor Assembly Replacement, Back Cover: paso 1, imagen 2 de 2
    • Remove the lid from the top of your Furbo Dog Camera.
  2. Furbo Dog Camera Barking Sensor Assembly Replacement: paso 2, imagen 1 de 3 Furbo Dog Camera Barking Sensor Assembly Replacement: paso 2, imagen 2 de 3 Furbo Dog Camera Barking Sensor Assembly Replacement: paso 2, imagen 3 de 3
    • Rotate your Furbo so that the bottom faces you.
    • Remove the rubber caps to reveal the four screws on the bottom of the Furbo.
  3. Furbo Dog Camera Barking Sensor Assembly Replacement: paso 3, imagen 1 de 3 Furbo Dog Camera Barking Sensor Assembly Replacement: paso 3, imagen 2 de 3 Furbo Dog Camera Barking Sensor Assembly Replacement: paso 3, imagen 3 de 3
    Herramienta utilizada en este paso:
    Flathead 3/32" or 2.5 mm Screwdriver
    $5.49
    Comprar
    • Use a 2.5 mm Flathead screwdriver to remove the four 5 mm screws from the bottom of the Furbo.
    • Use a 2.5 mm Flathead screwdriver to remove the single 5 mm screw under the silver sticker.
  4. Furbo Dog Camera Barking Sensor Assembly Replacement: paso 4, imagen 1 de 3 Furbo Dog Camera Barking Sensor Assembly Replacement: paso 4, imagen 2 de 3 Furbo Dog Camera Barking Sensor Assembly Replacement: paso 4, imagen 3 de 3
    • Rotate your Furbo so that the side is facing towards you.
    • Use an opening tool to separate the two plastic coverings.
  5. Furbo Dog Camera Barking Sensor Assembly Replacement: paso 5, imagen 1 de 2 Furbo Dog Camera Barking Sensor Assembly Replacement: paso 5, imagen 2 de 2
    • Once you have separated the two plastic coverings, remove one side by pulling on it and carefully separating it from the adhesive.
  6. Furbo Dog Camera Barking Sensor Assembly Replacement, Camera Lens: paso 6, imagen 1 de 3 Furbo Dog Camera Barking Sensor Assembly Replacement, Camera Lens: paso 6, imagen 2 de 3 Furbo Dog Camera Barking Sensor Assembly Replacement, Camera Lens: paso 6, imagen 3 de 3
    • Carefully remove the copper foiling that surrounds the camera hardware.
  7. Furbo Dog Camera Barking Sensor Assembly Replacement: paso 7, imagen 1 de 2 Furbo Dog Camera Barking Sensor Assembly Replacement: paso 7, imagen 2 de 2
    • Use a Phillips #000 screwdriver to remove the 2.5 mm screws at the top of the camera hardware.
  8. Furbo Dog Camera Barking Sensor Assembly Replacement: paso 8, imagen 1 de 2 Furbo Dog Camera Barking Sensor Assembly Replacement: paso 8, imagen 2 de 2
    • Gently pry the metal backing off of the camera hardware.
  9. Furbo Dog Camera Barking Sensor Assembly Replacement: paso 9, imagen 1 de 2 Furbo Dog Camera Barking Sensor Assembly Replacement: paso 9, imagen 2 de 2
    • Use a Phillips #000 screwdriver to remove the 0.4 mm screws that attach the camera to the Furbo case.
  10. Furbo Dog Camera Barking Sensor Assembly Replacement: paso 10, imagen 1 de 3 Furbo Dog Camera Barking Sensor Assembly Replacement: paso 10, imagen 2 de 3 Furbo Dog Camera Barking Sensor Assembly Replacement: paso 10, imagen 3 de 3
    • Gently pry the camera off and detach it from the Furbo.
  11. Furbo Dog Camera Barking Sensor Assembly Replacement: paso 11, imagen 1 de 3 Furbo Dog Camera Barking Sensor Assembly Replacement: paso 11, imagen 2 de 3 Furbo Dog Camera Barking Sensor Assembly Replacement: paso 11, imagen 3 de 3
    • Detach the wire attaching the camera hardware from the Furbo.
  12. Furbo Dog Camera Barking Sensor Assembly Replacement: paso 12, imagen 1 de 2 Furbo Dog Camera Barking Sensor Assembly Replacement: paso 12, imagen 2 de 2
    • Once removed, you may replace your camera.
  13. Furbo Dog Camera Barking Sensor Assembly Replacement, Barking Sensor Assembly: paso 13, imagen 1 de 1
    • Remove the barking sensor and replace it with a new part.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 5
Ultimos 30 días: 11
Todo El Tiempo: 156
