Saltar al contenido principal
Furbo Dog Camera Back Cover Replacement
Qué necesitas
  1. Furbo Dog Camera Back Cover Replacement, Back Cover: paso 1, imagen 1 de 2 Furbo Dog Camera Back Cover Replacement, Back Cover: paso 1, imagen 2 de 2
    • Remove the lid from the top of your Furbo Dog Camera.
  2. Furbo Dog Camera Back Cover Replacement: paso 2, imagen 1 de 3 Furbo Dog Camera Back Cover Replacement: paso 2, imagen 2 de 3 Furbo Dog Camera Back Cover Replacement: paso 2, imagen 3 de 3
    • Rotate your Furbo so that the bottom faces you.
    • Remove the rubber caps to reveal the four screws on the bottom of the Furbo.
  3. Furbo Dog Camera Back Cover Replacement: paso 3, imagen 1 de 3 Furbo Dog Camera Back Cover Replacement: paso 3, imagen 2 de 3 Furbo Dog Camera Back Cover Replacement: paso 3, imagen 3 de 3
    Herramienta utilizada en este paso:
    Flathead 3/32" or 2.5 mm Screwdriver
    $5.49
    Comprar
    • Use a 2.5 mm Flathead screwdriver to remove the four 5 mm screws from the bottom of the Furbo.
    • Use a 2.5 mm Flathead screwdriver to remove the single 5 mm screw under the silver sticker.
  4. Furbo Dog Camera Back Cover Replacement: paso 4, imagen 1 de 3 Furbo Dog Camera Back Cover Replacement: paso 4, imagen 2 de 3 Furbo Dog Camera Back Cover Replacement: paso 4, imagen 3 de 3
    • Rotate your Furbo so that the side is facing towards you.
    • Use an opening tool to separate the two plastic coverings.
  5. Furbo Dog Camera Back Cover Replacement: paso 5, imagen 1 de 2 Furbo Dog Camera Back Cover Replacement: paso 5, imagen 2 de 2
    • Once you have separated the two plastic coverings, remove one side by pulling on it and carefully separating it from the adhesive.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 10
Ultimos 30 días: 30
Todo El Tiempo: 1,150
