Saltar al contenido principal
Fulminare H13 True HEPA Air Purifier Ionizer Wires Replacement
Qué necesitas
  1. Fulminare H13 True HEPA Air Purifier Ionizer Wires Replacement, Ionizer Wires: paso 1, imagen 1 de 2 Fulminare H13 True HEPA Air Purifier Ionizer Wires Replacement, Ionizer Wires: paso 1, imagen 2 de 2
    • Turn off the unit and unplug it.
    • Twist the lid counterclockwise and lift it up to reveal the black filter.
  2. Fulminare H13 True HEPA Air Purifier Ionizer Wires Replacement: paso 2, imagen 1 de 2 Fulminare H13 True HEPA Air Purifier Ionizer Wires Replacement: paso 2, imagen 2 de 2
    • Using a Phillips screwdriver, remove the two 2 mm screws holding the filter in place.
  3. Fulminare H13 True HEPA Air Purifier Ionizer Wires Replacement: paso 3, imagen 1 de 2 Fulminare H13 True HEPA Air Purifier Ionizer Wires Replacement: paso 3, imagen 2 de 2
    • Pull apart the clips holding the shell together.
    • The clips can be tight, so don't be afraid to pull hard.
  4. Fulminare H13 True HEPA Air Purifier Ionizer Wires Replacement: paso 4, imagen 1 de 3 Fulminare H13 True HEPA Air Purifier Ionizer Wires Replacement: paso 4, imagen 2 de 3 Fulminare H13 True HEPA Air Purifier Ionizer Wires Replacement: paso 4, imagen 3 de 3
    • Using a Phillips screwdriver, remove the four 3.2 mm screws that secure the fan.
    • Lift the top clips off and pull the fan down and out.
  5. Fulminare H13 True HEPA Air Purifier Ionizer Wires Replacement: paso 5, imagen 1 de 1
    • Use a Phillips screwdriver to remove the two 1.25 mm screws holding the motherboard in place.
  6. Fulminare H13 True HEPA Air Purifier Ionizer Wires Replacement: paso 6, imagen 1 de 1
    • Pull the cables away from the connectors in the same direction as the individual wires are running.
    • Pull evenly on the full width of the cable so that no individual wires are overly strained.
Conclusión
Vera Penniston
Miembro Desde 05/24/23
133 Reputación
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 22
Todo El Tiempo: 172
