Saltar al contenido principal
Fujtsu Lifebook Model A6110 Keyboard Replacement
Qué necesitas
  1. Fujtsu Lifebook Model A6110 Keyboard Replacement, Battery: paso 1, imagen 1 de 2 Fujtsu Lifebook Model A6110 Keyboard Replacement, Battery: paso 1, imagen 2 de 2
    • The computer should be fully turned off and disconnected from the power source.
    • Before handling electronic components, you should ground yourself. This will prevent damage to the components from a static charge. You can do this by touching any metal object.
    • Flip your laptop so that the bottom of the laptop is facing up and the hinges of the screen are closest to you.
  2. Fujtsu Lifebook Model A6110 Keyboard Replacement: paso 2, imagen 1 de 1
    • To remove the battery, place your fingers underneath the two clips and simultaneously lift them up while pulling the cover towards you.
  3. Fujtsu Lifebook Model A6110 Keyboard Replacement, Keyboard: paso 3, imagen 1 de 3 Fujtsu Lifebook Model A6110 Keyboard Replacement, Keyboard: paso 3, imagen 2 de 3 Fujtsu Lifebook Model A6110 Keyboard Replacement, Keyboard: paso 3, imagen 3 de 3
    • Position the laptop like you would if you were to use it. Open the screen to a 180 degrees angle. The screen and the keyboard needs to face up before proceeding.
    • Using a flat edge of the plastic spudger, gently lift the piece of plastic located in the red square. Carefully insert the spudger between the inner edge marked by the arrow.
  4. Fujtsu Lifebook Model A6110 Keyboard Replacement: paso 4, imagen 1 de 3 Fujtsu Lifebook Model A6110 Keyboard Replacement: paso 4, imagen 2 de 3 Fujtsu Lifebook Model A6110 Keyboard Replacement: paso 4, imagen 3 de 3
    • With a Phillips #1 screwdriver, unscrew the four-six mm screws that were hidden under the plastic piece you removed.
  5. Fujtsu Lifebook Model A6110 Keyboard Replacement: paso 5, imagen 1 de 3 Fujtsu Lifebook Model A6110 Keyboard Replacement: paso 5, imagen 2 de 3 Fujtsu Lifebook Model A6110 Keyboard Replacement: paso 5, imagen 3 de 3
    • Lift up on the inner edges of the hinges for the screen. This will detach the face-plate from the computer. Use a spudger to make this process easier.
    • There is a ribbon underneath this panel that attaches to the motherboard. Be careful to not rip this ribbon.
    • The ribbon is located in the top left-hand corner and needs to carefully disconnected from the motherboard, as shown in the next step.
  6. Fujtsu Lifebook Model A6110 Keyboard Replacement: paso 6, imagen 1 de 2 Fujtsu Lifebook Model A6110 Keyboard Replacement: paso 6, imagen 2 de 2
    • Detach the ribbon from the motherboard, which will allow you to finish removing the face-plate from the computer.
    • To detach the ribbon, grip the ribbon at the base that is attached to the motherboard, which is the large green circuit-board in the body of the computer.
    • When reassembling the computer, make sure to reconnect the ribbons.
  7. Fujtsu Lifebook Model A6110 Keyboard Replacement: paso 7, imagen 1 de 2 Fujtsu Lifebook Model A6110 Keyboard Replacement: paso 7, imagen 2 de 2
    • There is another ribbon connecting the keyboard to the motherboard. Be careful not to rip it
    • The keyboard is now free. Lift up on the keyboard.
  8. Fujtsu Lifebook Model A6110 Keyboard Replacement: paso 8, imagen 1 de 1
    • This ribbon may be difficult to remove, so be careful in pulling it. You could accidentally break it.
    • Detatch the ribbon from the motherboard
    • When reassembling the computer, make sure to reconnect this ribbon.
Conclusión
Una persona más ha completado esta guía.
Cody Moniz
Miembro Desde 10/19/16
416 Reputación
4 Guías creadas
Equipo
UMass Dartmouth, Team 3-2, Isaacson Fall 2016 Miembro de UMass Dartmouth, Team 3-2, Isaacson Fall 2016
UMASSD-ISAACSON-F16S3G2
3 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 6
Todo El Tiempo: 545
