Saltar al contenido principal
Fujtsu Lifebook Model A6110 Battery Replacement
  1. Fujtsu Lifebook Model A6110 Battery Replacement, Battery: paso 1, imagen 1 de 2 Fujtsu Lifebook Model A6110 Battery Replacement, Battery: paso 1, imagen 2 de 2
    • The computer should be fully turned off and disconnected from the power source.
    • Before handling electronic components, you should ground yourself. This will prevent damage to the components from a static charge. You can do this by touching any metal object.
    • Flip your laptop so that the bottom of the laptop is facing up and the hinges of the screen are closest to you.
  2. Fujtsu Lifebook Model A6110 Battery Replacement: paso 2, imagen 1 de 1
    • To remove the battery, place your fingers underneath the two clips and simultaneously lift them up while pulling the cover towards you.
Conclusión
Alvin Thamrin
Miembro Desde 10/25/16
132 Reputación
1 Guía escrita
Equipo
UMass Dartmouth, Team 3-2, Isaacson Fall 2016 Miembro de UMass Dartmouth, Team 3-2, Isaacson Fall 2016
UMASSD-ISAACSON-F16S3G2
3 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 5
Todo El Tiempo: 408
