Introducción
If your laptop's battery dies too fast, or the battery indicator drops too quickly, then the battery may need replacement. This guide will show you the steps to remove the battery from your laptop.
Flip your laptop such that the bottom of the laptop is facing up.
Make sure you can read the label on the bottom part. If the label is upside down, you will need to re-position the laptop until you can properly read it. As an alternative, the hinges for the screen should be facing towards you.
Casi Terminas!
Conclusión
