Saltar al contenido principal
Fujitsu Siemens Amilo Pro Keyboard Replacement
Qué necesitas
  1. Fujitsu Siemens Amilo Pro Keyboard Replacement, Keyboard: paso 1, imagen 1 de 1
    • Remove AC adapter and battery.
    • Battery: pull the latch with a battery symbol beside it.
  2. Fujitsu Siemens Amilo Pro Keyboard Replacement: paso 2, imagen 1 de 1
    • Use a flat head screwdriver to pry out the hinge cover.
    • (Caution do not pull to hard as this could snap the plastic!)
  3. Fujitsu Siemens Amilo Pro Keyboard Replacement: paso 3, imagen 1 de 1
    • Remove the one screw holding in the keyboard.
  4. Fujitsu Siemens Amilo Pro Keyboard Replacement: paso 4, imagen 1 de 1
    • Pull the keyboard up towards you.
  5. Fujitsu Siemens Amilo Pro Keyboard Replacement: paso 5, imagen 1 de 1
    • Pull the ribbon cable and the keyboard will come out.
    • (Caution this ribbon is very delicate)
Conclusión
Una persona más ha completado esta guía.
Un comentario
try to focus the image while taking the picture so people can understand better were to touch
storm builder - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 9
Todo El Tiempo: 15,526
