Introducción
If your speakers are damaged or not working this guide will show you step-by-step instructions on how to replace your speakers
Qué necesitas
Remove the white sticker covering the screws (if applicable).
Use the PH1 screwdriver to remove the four 2 mm screws from the the backside of the device.
Remove the ten 3mm screws with a PH00 screwdriver from the shield.
Casi Terminas!
Conclusión
