Introducción
This guide will allow you to replace the motherboard if it is burnt up or to upgrade.
Qué necesitas
Remove the white sticker covering the screws (if applicable).
Use the PH1 screwdriver to remove the four 2 mm screws from the the backside of the device.
Remove the ten 3mm screws with a PH00 screwdriver from the shield.
3 personas más completaron esta guía.
