Introducción
This is another protective layer you will need to remove prior to accessing the internal parts of the device.
Qué necesitas
Remove the white sticker covering the screws (if applicable).
Use the PH1 screwdriver to remove the four 2 mm screws from the the backside of the device.
Remove the ten 3mm screws with a PH00 screwdriver from the shield.
Casi Terminas!
Conclusión
