Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Fujitsu Lifebook Stylistic Q584 Buttons Replacement
Qué necesitas
  1. Fujitsu Lifebook Stylistic Q584 Buttons  Replacement, Back Case: paso 1, imagen 1 de 1
    • Remove the white sticker covering the screws (if applicable).
    • Use the PH1 screwdriver to remove the four 2 mm screws from the the backside of the device.
  2. Fujitsu Lifebook Stylistic Q584 Buttons  Replacement: paso 2, imagen 1 de 1
    • Insert the plastic opening tool along the seam of the back case.
    • Gently slide the plastic opening tool along the entire seam popping the clips free.
  3. Fujitsu Lifebook Stylistic Q584 Buttons  Replacement: paso 3, imagen 1 de 1
    • Carefully lift the back case and remove the smartcard ribbon from the motherboard.
  4. Fujitsu Lifebook Stylistic Q584 Buttons  Replacement, Buttons: paso 4, imagen 1 de 1
    • Locate the plastic buttons on left side of the device.
  5. Fujitsu Lifebook Stylistic Q584 Buttons  Replacement: paso 5, imagen 1 de 1
    • Gently remove the plastic buttons.
Conclusión
Equipo
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 16
Ultimos 30 días: 48
Todo El Tiempo: 664
