Introducción
If the picture on the screen of the laptop is distorted or is blacked out then the screen may need to be replaced, this guide will show you how to remove the screen from the Fujitsu Lifebook S6120.
Qué necesitas
Push the two tabs in towards the laptop.
Lift the battery up and out from the frame of the laptop.
Use a plastic opening tool to lift the back of the hinge cover on the left and right sides of the computer.
Remove the 4mm screws from the laptop with a Philips head #0
Remove the 4.5mm screws on the back of the laptop with a Philips #0
