Saltar al contenido principal
Fujitsu Lifebook S6120 Screen Replacement
Qué necesitas
  1. Fujitsu Lifebook S6120 Screen Replacement, Battery: paso 1, imagen 1 de 3 Fujitsu Lifebook S6120 Screen Replacement, Battery: paso 1, imagen 2 de 3 Fujitsu Lifebook S6120 Screen Replacement, Battery: paso 1, imagen 3 de 3
    • To prevent injury, make sure the laptop is unplugged and turned off before removing the battery.
    • Push the two tabs in towards the laptop.
    • Lift the battery up and out from the frame of the laptop.
  2. Fujitsu Lifebook S6120 Screen Replacement, Hinge Cover: paso 2, imagen 1 de 2 Fujitsu Lifebook S6120 Screen Replacement, Hinge Cover: paso 2, imagen 2 de 2
    • Use a plastic opening tool to lift the back of the hinge cover on the left and right sides of the computer.
  3. Fujitsu Lifebook S6120 Screen Replacement: paso 3, imagen 1 de 1
    • Lift the hinge cover.
    • The hinge cover is connected to the motherboard by a ribbon cable. To prevent damage, lift hinge cover slowly.
  4. Fujitsu Lifebook S6120 Screen Replacement: paso 4, imagen 1 de 3 Fujitsu Lifebook S6120 Screen Replacement: paso 4, imagen 2 de 3 Fujitsu Lifebook S6120 Screen Replacement: paso 4, imagen 3 de 3
    • Use the tweezers to disconnect the ribbon cable from the motherboard.
  5. Fujitsu Lifebook S6120 Screen Replacement: paso 5, imagen 1 de 3 Fujitsu Lifebook S6120 Screen Replacement: paso 5, imagen 2 de 3 Fujitsu Lifebook S6120 Screen Replacement: paso 5, imagen 3 de 3
    • With the tweezers detach hinge cover cables from the motherboard.
    • Remove hinge cover.
  6. Fujitsu Lifebook S6120 Screen Replacement, Keyboard: paso 6, imagen 1 de 3 Fujitsu Lifebook S6120 Screen Replacement, Keyboard: paso 6, imagen 2 de 3 Fujitsu Lifebook S6120 Screen Replacement, Keyboard: paso 6, imagen 3 de 3
    • Lift keyboard enough to show the ribbon cable.
    • The keyboard has a ribbon cable attached to the motherboard. Lift keyboard carefully to prevent damage.
  7. Fujitsu Lifebook S6120 Screen Replacement: paso 7, imagen 1 de 3 Fujitsu Lifebook S6120 Screen Replacement: paso 7, imagen 2 de 3 Fujitsu Lifebook S6120 Screen Replacement: paso 7, imagen 3 de 3
    • Use a plastic opening tool to release the ribbon cable from the motherboard.
  8. Fujitsu Lifebook S6120 Screen Replacement, PCI Adapter: paso 8, imagen 1 de 3 Fujitsu Lifebook S6120 Screen Replacement, PCI Adapter: paso 8, imagen 2 de 3 Fujitsu Lifebook S6120 Screen Replacement, PCI Adapter: paso 8, imagen 3 de 3
    • Push the secure clips outward.
    • The Adapter should pop up.
  9. Fujitsu Lifebook S6120 Screen Replacement: paso 9, imagen 1 de 3 Fujitsu Lifebook S6120 Screen Replacement: paso 9, imagen 2 de 3 Fujitsu Lifebook S6120 Screen Replacement: paso 9, imagen 3 de 3
    • Use tweezers to remove the wires from the Adapter.
  10. Fujitsu Lifebook S6120 Screen Replacement: paso 10, imagen 1 de 2 Fujitsu Lifebook S6120 Screen Replacement: paso 10, imagen 2 de 2
    • Take out the Adapter and carefully pull the wires out from the metal casing.
  11. Fujitsu Lifebook S6120 Screen Replacement, Screen: paso 11, imagen 1 de 2 Fujitsu Lifebook S6120 Screen Replacement, Screen: paso 11, imagen 2 de 2
    • Remove the 4mm screws from the laptop with a Philips head #0
    • Remove the 4.5mm screws on the back of the laptop with a Philips #0
  12. Fujitsu Lifebook S6120 Screen Replacement: paso 12, imagen 1 de 3 Fujitsu Lifebook S6120 Screen Replacement: paso 12, imagen 2 de 3 Fujitsu Lifebook S6120 Screen Replacement: paso 12, imagen 3 de 3
    • Use a plastic opening tool to lift up both sides of the white tab.
  13. Fujitsu Lifebook S6120 Screen Replacement: paso 13, imagen 1 de 2 Fujitsu Lifebook S6120 Screen Replacement: paso 13, imagen 2 de 2
    • Use tweezers to grab onto the lever to remove the chip from the motherboard.
  14. Fujitsu Lifebook S6120 Screen Replacement: paso 14, imagen 1 de 1
    • Lift the screen up vertically
  15. Fujitsu Lifebook S6120 Screen Replacement: paso 15, imagen 1 de 3 Fujitsu Lifebook S6120 Screen Replacement: paso 15, imagen 2 de 3 Fujitsu Lifebook S6120 Screen Replacement: paso 15, imagen 3 de 3
    • Remove rubber tabs with hands
    • Use a Philips head #0 to remove the 3mm screws
  16. Fujitsu Lifebook S6120 Screen Replacement: paso 16, imagen 1 de 2 Fujitsu Lifebook S6120 Screen Replacement: paso 16, imagen 2 de 2
    • Use the metal spudger to pry up the edge of the plastic casing up.
    • Remove the plastic frame from the screen.
  17. Fujitsu Lifebook S6120 Screen Replacement: paso 17, imagen 1 de 1
    • Remove the 3mm screws with a Philips head #00
  18. Fujitsu Lifebook S6120 Screen Replacement: paso 18, imagen 1 de 1
    • Remove the 2.5mm screws with a Philips head #0 on both sides of the laptop
  19. Fujitsu Lifebook S6120 Screen Replacement: paso 19, imagen 1 de 2 Fujitsu Lifebook S6120 Screen Replacement: paso 19, imagen 2 de 2
    • Lift the screen from the frame
  20. Fujitsu Lifebook S6120 Screen Replacement: paso 20, imagen 1 de 2 Fujitsu Lifebook S6120 Screen Replacement: paso 20, imagen 2 de 2
    • Remove the ribbon from the back of the screen
  21. Fujitsu Lifebook S6120 Screen Replacement: paso 21, imagen 1 de 3 Fujitsu Lifebook S6120 Screen Replacement: paso 21, imagen 2 de 3 Fujitsu Lifebook S6120 Screen Replacement: paso 21, imagen 3 de 3
    • Use a pair of tweezers remove the white connector
Conclusión
Jessi Gallant
Miembro Desde 03/19/18
899 Reputación
7 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 8
Todo El Tiempo: 931
