Saltar al contenido principal
Fujitsu Lifebook S6120 RAM Replacement
Qué necesitas
  1. Fujitsu Lifebook S6120 RAM Replacement, Battery: paso 1, imagen 1 de 3 Fujitsu Lifebook S6120 RAM Replacement, Battery: paso 1, imagen 2 de 3 Fujitsu Lifebook S6120 RAM Replacement, Battery: paso 1, imagen 3 de 3
    • To prevent injury, make sure the laptop is unplugged and turned off before removing the battery.
    • Push the two tabs in towards the laptop.
    • Lift the battery up and out from the frame of the laptop.
  2. Fujitsu Lifebook S6120 RAM Replacement, RAM: paso 2, imagen 1 de 2 Fujitsu Lifebook S6120 RAM Replacement, RAM: paso 2, imagen 2 de 2
    • Use a Philips head #0 to remove the 4mm screws to the RAM cover.
  3. Fujitsu Lifebook S6120 RAM Replacement: paso 3, imagen 1 de 3 Fujitsu Lifebook S6120 RAM Replacement: paso 3, imagen 2 de 3 Fujitsu Lifebook S6120 RAM Replacement: paso 3, imagen 3 de 3
    • Use the plastic opening tool to lift the RAM cover.
    • Use your hands to slide the cover off.
  4. Fujitsu Lifebook S6120 RAM Replacement: paso 4, imagen 1 de 3 Fujitsu Lifebook S6120 RAM Replacement: paso 4, imagen 2 de 3 Fujitsu Lifebook S6120 RAM Replacement: paso 4, imagen 3 de 3
    • Remove RAM module by pushing security clips outward.
    • The RAM module should pop out.
    • Carefully pull RAM module out of the computer.
Conclusión
Jessi Gallant
Miembro Desde 03/19/18
899 Reputación
7 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 5
Todo El Tiempo: 392
