Saltar al contenido principal
Fujitsu Lifebook S6120 Keyboard Replacement
Qué necesitas
  1. Fujitsu Lifebook S6120 Keyboard Replacement, Battery: paso 1, imagen 1 de 3 Fujitsu Lifebook S6120 Keyboard Replacement, Battery: paso 1, imagen 2 de 3 Fujitsu Lifebook S6120 Keyboard Replacement, Battery: paso 1, imagen 3 de 3
    • To prevent injury, make sure the laptop is unplugged and turned off before removing the battery.
    • Push the two tabs in towards the laptop.
    • Lift the battery up and out from the frame of the laptop.
  2. Fujitsu Lifebook S6120 Keyboard Replacement, Hinge Cover: paso 2, imagen 1 de 2 Fujitsu Lifebook S6120 Keyboard Replacement, Hinge Cover: paso 2, imagen 2 de 2
    • Use a plastic opening tool to lift the back of the hinge cover on the left and right sides of the computer.
  3. Fujitsu Lifebook S6120 Keyboard Replacement: paso 3, imagen 1 de 1
    • Lift the hinge cover.
    • The hinge cover is connected to the motherboard by a ribbon cable. To prevent damage, lift hinge cover slowly.
  4. Fujitsu Lifebook S6120 Keyboard Replacement: paso 4, imagen 1 de 3 Fujitsu Lifebook S6120 Keyboard Replacement: paso 4, imagen 2 de 3 Fujitsu Lifebook S6120 Keyboard Replacement: paso 4, imagen 3 de 3
    Herramienta utilizada en este paso:
    Comprar
    • Use the tweezers to disconnect the ribbon cable from the motherboard.
  5. Fujitsu Lifebook S6120 Keyboard Replacement: paso 5, imagen 1 de 3 Fujitsu Lifebook S6120 Keyboard Replacement: paso 5, imagen 2 de 3 Fujitsu Lifebook S6120 Keyboard Replacement: paso 5, imagen 3 de 3
    • With the tweezers detach hinge cover cables from the motherboard.
    • Remove hinge cover.
  6. Fujitsu Lifebook S6120 Keyboard Replacement, Keyboard: paso 6, imagen 1 de 3 Fujitsu Lifebook S6120 Keyboard Replacement, Keyboard: paso 6, imagen 2 de 3 Fujitsu Lifebook S6120 Keyboard Replacement, Keyboard: paso 6, imagen 3 de 3
    • Lift keyboard enough to show the ribbon cable.
    • The keyboard has a ribbon cable attached to the motherboard. Lift keyboard carefully to prevent damage.
  7. Fujitsu Lifebook S6120 Keyboard Replacement: paso 7, imagen 1 de 3 Fujitsu Lifebook S6120 Keyboard Replacement: paso 7, imagen 2 de 3 Fujitsu Lifebook S6120 Keyboard Replacement: paso 7, imagen 3 de 3
    • Use a plastic opening tool to release the ribbon cable from the motherboard.
Conclusión
Una persona más ha completado esta guía.
Jessi Gallant
Miembro Desde 03/19/18
899 Reputación
7 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 32
Todo El Tiempo: 1,090
