Saltar al contenido principal
Fujitsu Lifebook S6120 Hinge Cover Replacement
Qué necesitas
  1. Fujitsu Lifebook S6120 Hinge Cover Replacement, Battery: paso 1, imagen 1 de 3 Fujitsu Lifebook S6120 Hinge Cover Replacement, Battery: paso 1, imagen 2 de 3 Fujitsu Lifebook S6120 Hinge Cover Replacement, Battery: paso 1, imagen 3 de 3
    • To prevent injury, make sure the laptop is unplugged and turned off before removing the battery.
    • Push the two tabs in towards the laptop.
    • Lift the battery up and out from the frame of the laptop.
  2. Fujitsu Lifebook S6120 Hinge Cover Replacement, Hinge Cover: paso 2, imagen 1 de 2 Fujitsu Lifebook S6120 Hinge Cover Replacement, Hinge Cover: paso 2, imagen 2 de 2
    • Use a plastic opening tool to lift the back of the hinge cover on the left and right sides of the computer.
  3. Fujitsu Lifebook S6120 Hinge Cover Replacement: paso 3, imagen 1 de 1
    • Lift the hinge cover.
    • The hinge cover is connected to the motherboard by a ribbon cable. To prevent damage, lift hinge cover slowly.
  4. Fujitsu Lifebook S6120 Hinge Cover Replacement: paso 4, imagen 1 de 3 Fujitsu Lifebook S6120 Hinge Cover Replacement: paso 4, imagen 2 de 3 Fujitsu Lifebook S6120 Hinge Cover Replacement: paso 4, imagen 3 de 3
    • Use the tweezers to disconnect the ribbon cable from the motherboard.
  5. Fujitsu Lifebook S6120 Hinge Cover Replacement: paso 5, imagen 1 de 3 Fujitsu Lifebook S6120 Hinge Cover Replacement: paso 5, imagen 2 de 3 Fujitsu Lifebook S6120 Hinge Cover Replacement: paso 5, imagen 3 de 3
    • With the tweezers detach hinge cover cables from the motherboard.
    • Remove hinge cover.
Conclusión
Jaimie Nakamura
Miembro Desde 03/20/18
229 Reputación
2 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 7
Todo El Tiempo: 345
